Mallory 685 stumble
Old Apr 8, 2005 | 01:14 PM
97Z-pimp's Avatar
Mallory 685 stumble
Ok i hooked up my mallory 685 yesterday and when i am just crusing i can feel it stumble sometimes. The only setting i changed was the first rev limiter because the nitrous system is not hooked up yet. Should the other settings be changed, because the system cant really be hooked up wrong. The harness and then the power and ground. Any ideas?
Old Apr 8, 2005 | 02:15 PM
Loadre's Avatar
Re: Mallory 685 stumble
Stick in the bypass connector so you're bypassing the box then report back to us.
Old Apr 8, 2005 | 02:55 PM
97Z-pimp's Avatar
I bypassed it and the stumble is gone. runs great...so now what?
Old Apr 8, 2005 | 03:44 PM
Loadre's Avatar
Did you buy the box brand new? When I bought mine it was a looong time ago and it was the early version. There was a software issue that made the car not run correctly when the high speed retard was hooked up a certain way. Is your high speed retard hooked up yet. Or are the only things you have hooked up a 12v power, ground, and the connector?
Old Apr 8, 2005 | 03:49 PM
97Z-pimp's Avatar
I got it new off a mebmer here(gb95zconv) And yes all i hooked up was 12V power, ground, and connector
Old Apr 8, 2005 | 08:54 PM
Loadre's Avatar
One thing to check. It's increasing your spark intensity so if you have a plug wire arcing or something it will only make the problem worse. Go to a pitch black area and pop your hood and start the car and see if anything is arcing (you'll know it if you see it). I'll post up some more tomorrow, pretty tired right now.
Old Apr 9, 2005 | 07:25 PM
97Z-pimp's Avatar
Thats a good idea. Tonight i will try that out.
93 RedBird
Nov 15, 2015 08:24 AM
n2oblkz
Oct 22, 2015 02:31 PM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
