Make your own header kit????
Old Oct 26, 2003 | 10:19 PM
dnz28's Avatar
i really want to makw my own headers, do yall know where I can get a kit for the lt1. I checked summit and jegs but it dont look like those will fit.
Old Oct 26, 2003 | 10:35 PM
FacelessZ's Avatar
save your money somewhere else...lol...
Old Oct 27, 2003 | 01:44 PM
dnz28's Avatar
un like everyone else I like parts that are unqie fawker so your cheapy remarks can be kept to your self. I want 2in primes thats why I am lookin for a kit because i cant find a set premade. And I now how to do it.
Old Oct 27, 2003 | 01:50 PM
drewstealth's Avatar
I don't think they sell a kit for the lt1's. But if you know how why don't you just custom bend all the pipes? But honestly i would just spend the extra money on some proven headers.
Old Oct 27, 2003 | 01:51 PM
grendal's Avatar
I'm not sure where you can get a kit. Any kit for a SBC should fit though....
On the other hand, your motor is gonna run like crap with 2" primaries unless you're building a 7,500rpm high-end road-race motor or something. Honestly, 2" primaries will have no torque. You won't find 2" primary headers for ANY small-block engine. Not even racing headers are 2".
-Michael
Old Oct 27, 2003 | 01:53 PM
ibanez6rg's Avatar
I believe Jet-Hot sells a header kit - Costs around $5xx.xx
They ship 'em to you and you slap 'em on!
Old Oct 27, 2003 | 02:04 PM
dnz28's Avatar
Cool. that the goal I am making a 355 that hopfully will spin way above 8500. just hope. also for someone who asked why dont I just custom bend pipes, well I personally like to built it while its on the car, and bending pipes would be ez but then you always run into problems where you missed measured by just a little bit. well at least I always run into problems
Old Oct 27, 2003 | 02:22 PM
jonaddis84's Avatar
What PCM will be handling the 8500 RPMS??
Old Oct 27, 2003 | 02:31 PM
dnz28's Avatar
nope, I will have to get a after market ignition contoller.
Old Oct 27, 2003 | 03:23 PM
jonaddis84's Avatar
I dont want to be rude or a dick or anything, but this sounds like an outrageous setup you are going for here. Not even any DFI that I know of, accell, edelbrock, holley, none of those even handle anything above 7500max I dont think. Plus you will need some crazy *** heads to give you that much air also, also thats seems like a few too many rpms for an lt1 block. I dont see the point of spinning that high myself, but im sure there is a good reason, and maybe you have thought this out much more than it sounds like.
Old Oct 27, 2003 | 03:39 PM
jonaddis84's Avatar
You might fit them, Dynatech makes 1-7/8" primaries, and I believe big blocks run 2-1/4 on high hp engines. I still just dont see the need for that large of a primary for SBC, and cant justify the cost. It is possible though, and would be cool, if it worked.
Old Oct 27, 2003 | 04:56 PM
Originally posted by jonaddis84
I dont want to be rude or a dick or anything, but this sounds like an outrageous setup you are going for here. Not even any DFI that I know of, accell, edelbrock, holley, none of those even handle anything above 7500max I dont think...........
My MoTeC M48Pro is good for over 15,000rpm. My engine isn't .
Dart Iron Eagle block, SBC/Brodix 23* heads with spread center-port exhaust, with 2" primary (step design) custom headers
The above engine is configured to fit into a 30th SS Convertible. Engine is a 383ci, Vortech S/C'd, MoTeC M800 engine management, with approx. 1,500 flywheelHP.
Old Oct 27, 2003 | 05:50 PM
TreySpeed's Avatar
On permanent vacation
it takes about 3 FULL 8-10 hour days for a PROFESSIONAL to fab up a set of full length headers with every possible tool imagineable. and thats for a race motor with tons of room.
I was talking to a guy at work that was fabbing up headers for a ford (which goes IEIEIEIE, not IEIEEIEI and makes it much simpler)
there is also a LOT (and i mean a lot) of engineering behind the layout and design of them. they can VASTLEY affect performance- especially in the 8000 rpm range .
You really- and I mean REALLY need to know wtf you are doing (read: you better have some hard core edumacation and race expierence- not just welding capabilities)
Good luck in your endevours.
Old Oct 27, 2003 | 05:59 PM
Javier97Z28's Avatar
Moderator
I take it that's Baxter's motor right?
Old Oct 27, 2003 | 06:00 PM
nateh's Avatar
I know a guy who has 2" primaries on his LT1. They are SB2 heads, but the headers do indeed fit. It's for a seriously fast car running a boatload of nitrous.
Headers by Ed
This guy will sell you a kit with pre-bent pipes that you cut to fit your application. You can build them on the car exactly as you envision. Check in the header kits section.
