Major problems!
Old Aug 19, 2004 | 08:30 PM
Munson's Avatar
Major problems!
hey, i decided to go ahead and put the 54mm tb instead of doing everything all at once... I can actually feel a pretty good difference with the new throttle body but somethings not right. Its an A4 and if i punch it at about 15-20 shift out of first then go through second and shift into third it feels awesome but then right after i shift into third the power falls off completely like it shifts into od i think and after that happens it will stay in overdrive until i go fairly slow and oonce i come to a stop and start driving again it will stick in the gears and when it finaly shifts its fast and firm.. i checked the tps it reads .70v at idle and 4.8 wot.. the idle is fine also.. the only other thing i noticed wrong was when i reved the engine in nutral it would stay at 2k rpms when it was comming back down and to get it to come all the way down i had to tap the gas real quick.. any suggestions? by the way everything else is stock ss stuff
Old Aug 19, 2004 | 10:49 PM
Munson's Avatar
Re: Major problems!
help?
Old Aug 19, 2004 | 11:06 PM
Re: Major problems!
Did you check for any binding of the throttle blades with the cables off?
Old Aug 19, 2004 | 11:09 PM
Munson's Avatar
Re: Major problems!
its an as&m everything is tip top.. everything is perfect until i go through the gears like mentioned..
Old Aug 19, 2004 | 11:14 PM
Munson's Avatar
Re: Major problems!
any ideas? i really wanna get this thing runnin right
Old Aug 19, 2004 | 11:32 PM
Re: Major problems!
Well, if something is sticking and it's not the TB, check the throttle cable.
Old Aug 20, 2004 | 12:30 AM
Munson's Avatar
Re: Major problems!
it only sticks every now and then but i think i got that problem fixed the main issue i was having was when i was WOT and it shifts it completely F's up.. when i get on it completely afterwards the gears start sticking like i will just ease in first gear and it will normally shift out it will stay in first gear till like 2800 rpm then snap into the next gear.
Old Aug 20, 2004 | 12:38 AM
97WS6SCharged's Avatar
Re: Major problems!
Talk to Ion or Brain about increasing the line pressures in the 4L60E. I would also swap the stocker back onto the car until you can get this taken care of or you'll probably be rebuilding your 14k mile tranny pretty soon.
Old Aug 20, 2004 | 12:53 AM
Munson's Avatar
Re: Major problems!
why would it have anything to do with my line pressure though? its just at WOT it will go through a gear then shift and after the shift it messes up like the computer.. and it starts shifting wrong.. if i dont get on it at all it doesnt do it and it runs just fine when it starts doing it turning off the car then turning it back on fixes it
Old Aug 20, 2004 | 01:05 AM
Re: Major problems!
It's just a known problem. When you put a bigger TB on a car with an electronic tranny, you have to up the line pressures or it kills the trans. Just call one of the two guys I mentioned earlier and talk to them about it.
Old Aug 20, 2004 | 01:06 AM
Munson's Avatar
Re: Major problems!
alright thanks for the advice
btw who is brian? what is his name on here?
Old Aug 20, 2004 | 01:21 AM
Re: Major problems!
Brian is the guy at PCM4Less. Ion runs MadZ28.com. Both are tuners and both do quality work. I believe Ion is Madwolf on this board. Haven't talked to him in a while though.
Old Aug 20, 2004 | 01:23 AM
Munson's Avatar
Re: Major problems!
damn, so the pcm has to be retuned to increase tranny line pressure?
Old Aug 20, 2004 | 01:30 AM
Re: Major problems!
Yep. Like I said, swap back to the stocker until you can get that done.
96SilverRam
May 5, 2015 09:56 PM
karnykamaro
Feb 2, 2015 01:37 PM
Jazsun
Dec 29, 2014 12:14 PM
