Main studs.?
Old Aug 13, 2005 | 04:46 PM
96ta(nick)'s Avatar
Main studs.?
Do i order them for small or large journal 2bolt?
Old Aug 13, 2005 | 07:40 PM
94zgreenmachine's Avatar
Re: Main studs.?
large journal. I believe the small journal were the older 327. Then there were the larger journal 327 and I believe the 350 journals were always the large journal. Careful when ordering, I ordered a 4 bolt kit with use of windage tray and they didn't fit the tray.
Old Aug 13, 2005 | 08:14 PM
1racerdude's Avatar
Re: Main studs.?
Get the set for a 400 SBC and the tray will bolt back on. Call ARP and they will give ya the correct set number and ya can get them from Summett.
Old Aug 13, 2005 | 09:19 PM
Re: Main studs.?
1racerdude, I thought I remember you posting that once before, but I couldn't remember for sure. Glad you chimed in!
Old Aug 13, 2005 | 10:36 PM
96ta(nick)'s Avatar
Re: Main studs.?
070-234-5606 SB-Chevy 400ci Main Studs with Hex Nuts, 4-Bolt Main with Windage Tray CartMe! $79.99
Those? I am staying with the 2 bolt mains will those work but just not use all the bolts?
Old Aug 14, 2005 | 01:36 AM
MachinistOne's Avatar
Re: Main studs.?
Arp-234-5501
Old Aug 14, 2005 | 02:22 AM
Re: Main studs.?
Originally Posted by MachinistOne
Arp-234-5501
I'd be skeptical about that number. I bought 234-5601 for a 4- bolt and the windage tray didn't work. You ABSOLUTELY want to keep it.
Old Aug 14, 2005 | 10:55 AM
89385formula's Avatar
Re: Main studs.?
I would get the studs for large journal 2 bolt mains, without windage tray. Then, i would buy an aftermarket pan, with a built in windage tray, and other nice features like higher oil capacity. Thats just me though, i have heard the factory windage tray is a pretty crappy design from the local engine builders. I believe there is an issue with that part number that machinist gave....because you i think our trays have an extra bolt holding it down, I am not 100% sure, but when I called my engine builder he said something like that.
Old Aug 14, 2005 | 05:47 PM
Re: Main studs.?
I didn't say that's the right one to use, just that's the part number for the application that was asked for
Personally - I do what was stated below - Use the standard main stud kit and use an aftermarket pan with built in tray and scraper.
Old Aug 14, 2005 | 08:36 PM
Re: Main studs.?
Personally - I do ......
and I gave him a heads up
Old Aug 15, 2005 | 09:47 PM
Re: Main studs.?
So we both did our jobs
Old Aug 15, 2005 | 11:03 PM
96ta(nick)'s Avatar
Re: Main studs.?
What does an aftermarket pan cost?
Old Aug 15, 2005 | 11:44 PM
Re: Main studs.?
well it depends on which you get. I went with the Canton 242-T I think it was...around $280 for the pan and $25 or so for the pickup.
Old Aug 15, 2005 | 11:57 PM
96ta(nick)'s Avatar
Re: Main studs.?
Can i just have the machine shop make me a new tray that will work with the studs?
RUENUF
Mar 13, 2016 03:37 PM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ericksd
Jan 20, 2016 06:07 PM
heus
Sep 8, 2015 12:01 PM
carolinacasper
Jul 22, 2015 04:47 PM
