Main bolts and windage tray???
Old Sep 26, 2009 | 02:15 PM
SC/TA's Avatar
I got my block back from the machine shop. Its a 4 bolt main block and will be a 383. It had ARP bolts in it when I got it back from them. So I assume it was align honed with these bolts. My question is what are my options for a windage tray? Obviously it wont work with these bolts. Should I go with a different pan with a windage tray already installed in it or what? I have done some searching but most everything is talking about useing stock windage tray with main studs.
Old Sep 27, 2009 | 04:50 PM
SC/TA's Avatar
Any ideas? I think a different pan will be my best bet, but i am open to other options.
Old Sep 30, 2009 | 02:29 PM
SC/TA's Avatar
Bump. I need some help guys.
Old Sep 30, 2009 | 02:35 PM
ulakovic22's Avatar
Easiest way would be to just get a pan with a windage tray already. I don't even think the stock windage tray would clear a 3.75 stroke anyway, I had issues with just 6" eagle h-beams and the stock windage tray.
Old Sep 30, 2009 | 02:37 PM
Airbornec507's Avatar
I had my machine shop weld in longer studs on the bottom of the splayed bolts and install the stock windage tray. I still run the stock oil pan with a high volume pump and so far so good after 3k miles.
Old Sep 30, 2009 | 02:58 PM
dangalla's Avatar
a stock oil pan with a high volume oil pump is asking for disaster. the pump out-pumps the amount of oil in the pan
Old Sep 30, 2009 | 03:34 PM
RUDEDOG's Avatar
No one can prove that. I've been running hv and stock pan for years without a problem.
Old Sep 30, 2009 | 04:22 PM
That may be true. That's why I do have a canton w/ a hv oil pump and pickup for that pan waiting to be put in. However time is not on my side as I'm a bussy person. I know that there are folks who have had issues with this. However so far with many high rpm track passes after 3k it's still running good.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
maybe2fast
Mar 16, 2015 09:45 AM
