Main bearings - hard to change?
Old Aug 13, 2006 | 05:38 PM
pyrojoex28's Avatar
I've noticed a decline in oil pressure in my car lately. Driving down the road at 60, the gauge shows around 25-30 lbs of pressure. It used to hover around 40 after it was warmed up.
My dad said changing the main bearings could fix the problem. Does this involve a significant amount of work? Cost?
Old Aug 13, 2006 | 06:15 PM
Daniel6718's Avatar
Re: Main bearings - hard to change?
yes, you pretty much have to have the motor out...
Old Aug 13, 2006 | 06:20 PM
Red_94Formula's Avatar
That does not seem like bad pressure. What is the presure at idle? 15 psi is good at idle.
Old Aug 13, 2006 | 08:24 PM
ShowStopper540's Avatar
i agree, the oil pressure may be lower, but its not necesarily bad...it could be a number of things, but your main bearings have nothing to do with it, the CAM bearings are where your oil pressure comes from...either one (cams or mains) you replace, it will be a pulling out the motor job, if i were you, id start simple, possible and oil pressure sending unit? if not that...then maybe the oil pump itself, id only resort to bearings as a last thing id do
HectorM52
Jul 30, 2017 11:46 AM
carl.froehlich
Mar 13, 2015 12:38 AM
silvermansteve
Mar 4, 2015 05:02 PM
armedtrigger
Feb 24, 2015 08:30 PM
