Mail order tune for solid roller 383
Old Apr 20, 2013 | 09:12 PM
  #31
PA94Z's Avatar
Re: Mail order tune for solid roller 383
Thanks guys for the replys.
Injuneer - I am going to have to look into that further, Seems like the best option.
KW - That would be a perfect solution, but the timing is just no good.....
slick - Looks like a really nice setup. Trying to work with what I have right now, but maybe a future purchase.
Old Apr 21, 2013 | 12:55 PM
  #32
KW Baraka's Avatar
Originally Posted by PA94Z
......KW - That would be a perfect solution, but the timing is just no good......
I feel ya.....sometimes life (and what you have to do) gets in the way of what you want to do.
But after a year of dealing with this.......you may need to find a way to somehow make it work.
Best of luck; hope you get this sorted out!!
KW
Old Apr 21, 2013 | 10:21 PM
  #33
PA94Z's Avatar
KW you are right, I spent to much time and money on this build to drive on a bad tune up. I fixed idle issues and very lean areas, but it still could improve. I have to disconnect the battery after each pass or the LTFT adds fuel at WOT.
I believe Bryan is actually closer to me than the trip he will make up to Philly area. I want to say an hour away.. I will contact him and get some more info, I just wont get a Dyno Day discount...
I wired the analog output to the AC pressure switch and the PCM can record feedback now, it's just in pressure, not voltage, or AF - so I have to graph it against what the wide band displays at what pressure. Wasn't a big success today.
I did play with the AF a bit though and found it likes 12.5 more than 12.8 or 12.9 (reported on my display). It also likes more timing advance than 34*.. the last two passes today I bumped it a degree on each, picking up MPH on each. Here is the best 2 out of 6 passes of the day...
DA -200 ft, 2nd pass
34* advance 12.5:1 AFR
1,55 60 ft
7.05 @ 98.71
11.06 @ 122.88
DA +400 ft last pass
36* advance 12.5:1 AFR
1.56 60 ft
7.06 @ 98.75
11.07 @ 123.05
I was happy with the times.. would have like a 10.9 pass Other times were 11.08, 11.08, 11.12, and 11.27. Pretty consistent.. The 60 ft stayed at 1.55 consistently, with some variation due to wheel spin.
At this time I am a little suspension away from my ET goal. Stock shocks and springs need to go at some point. Along with a restall or new converter after I get this dyno tuned.
Anyway thanks for the help guys
cmyname1
Feb 19, 2015 08:38 PM
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
