MAF wire inside is broken
Old Nov 10, 2006 | 05:14 PM
mdacton's Avatar
one of the little wires inside is broken in my MAF. it is setting the code for it
my question is how much of a problem is this going to cause me? i want to go to the track sunday to try a few new things, if i won't get the best out of it without a good MAF my other options are
1 i have a good 3" maf i can use a 3.5" to 3" coupler on it
2 buy one at autozone for $150
3 take one off of a 2000 1500 truck with a 4.8L
will any of these work well or should I just leave it off?
I will get a new one but i wont be able to get it by sunday, just want to see if i have any temp. options
Old Nov 10, 2006 | 05:40 PM
MeanGreen97Z's Avatar
You can try to solder it.
Old Nov 10, 2006 | 06:34 PM
mdacton's Avatar
its too small....like soldering a light bulb
i am going to try it tho right now
Old Nov 10, 2006 | 06:37 PM
Shouldnt be too hard if you hold it with some tweezers.
Old Nov 10, 2006 | 08:42 PM
Zacks 97WS6's Avatar
Just had a bad MAF on my girlfriend's Z/28. At the track at WOT it would go lean and set a code. Was running 9.3 in the 1/8 (LS1 Car) Got new MAF (GM)of the bay for $75.00 and ran 8.8. Did a PCM For less dyno tune and ran an 8.5. Dang LS1 cars So unless you get a new MAF don't waste you money on track time.
Zack
carl.froehlich
Mar 13, 2015 12:38 AM
mattstrike
Mar 11, 2015 07:33 PM
pete53
Dec 9, 2014 07:31 AM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
x7x7
Aug 15, 2002 06:49 PM
