MAF screens???
Old Apr 30, 2003 | 11:05 AM
IrocManiac's Avatar
MAF screens???
Guys I was talking to a friend of mine yesterday and he asked if I had pulled the screens on my MAF, I had done it to my IROC but didn't know they had screens on the 4th gen MAF's is there any reason to leave it on or should I pull them off??
Old Apr 30, 2003 | 11:14 AM
Bastardcat's Avatar
2319 Posts and you haven't come across a thread on this yet? Pull the screen off (carefully) and if you don't like the results put it back on. Before someone beats me on this one...do a search.
(Matter of fact, this same topic came up yesterday.)
Old Apr 30, 2003 | 11:53 AM
Unlike the 3rd Gen MAF, the 4th Gen unit only has one screen, on the inlet side. It really isn't much of an obstruction, and does contribute to maintaining the calibration of the meter. Some people remove the screen and find a rough idle or lost fuel mileage. Others find a truely miraculous SOTP gain, and "faster throttle response" (whatever that is ). On a lot of the early sensors, you just need to pull the spring ring out of the groove and the screen can be taken out without damage, and reinstalled if you don't like the results. I think some of the newer models can not be removed without destroying the screen.
The 4th Gen uses a real "GM" MAF, and it is not a flow restriction like the Bosch unit used in the 3rd Gens. They would respond very well to removing the TWO screens and cutting out the cooling fins.. but the 4th Gens don't offer as much opportunity.
Old Apr 30, 2003 | 02:19 PM
IrocManiac's Avatar
Cool thats what I wanted to know (I didn't know they had screens till yesterday guess the ones I'd seen the guys had pulled them) if it doesn't offer much obstruction I'm just gonna leave it. It made a good difference on my 3rd gen but as you said it was a bosch unit also the screens were pretty dang thick so I could definately see how that could onstruct air flow...thanks...
Old Apr 30, 2003 | 03:35 PM
As I recall, the screens in the Bosch MAF's were actually "screens" made out of fairly heavy metal wire. The screen in the GM MAF is made out of a layered foil and paper, and pulled into a sheet with hex-shaped openings.... very little lost cross-sectional area.
Old Apr 30, 2003 | 04:51 PM
IrocManiac's Avatar
Yeah those bosch's had some actual screens on them, if these are less restrictive I'll leave it alone...
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
