MAF problems....please help!
Old Mar 4, 2004 | 05:25 PM
97Camaro007's Avatar
Well my MAF is reading 0......so i thought that it was just unhooked.....it was plugged in....well does that mean that the MAF is broke and I need a new one....because i took one off of a ls1 car just to make sure that it was the problem and it read 0 also.....does the MAF have a ground somewhere that I may have over looked.....? Help me get this thing at least running right again....Thanks
Michael
Old Mar 5, 2004 | 12:05 AM
The MAF needs +12V from the pink wire on the connector. Pull the plug off and check for +12V with the key on. It is not unusual for the pink wire to lose power. It comes off the harness near the PCM, and is supplied by a fuse in different locations in different years. Also check for a good ground on the black/white wire on the connector.
Old Mar 5, 2004 | 12:27 AM
found it.....it was a fuse under the hood labeled engine sensor.....thanks for everyones help...
Michael
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
