"big size cams" and stall size
Old Mar 3, 2004 | 12:55 AM
QCKZ28's Avatar
for ppl with a big cam (cc306, gm847, XE233/239) what stall speed are you running?
jesse
Old Mar 3, 2004 | 10:51 AM
ChuckZ28's Avatar
my cam is 236/244 duration with .608/.614 lift and I am running with a 3200 stall 10 inch converter. Im going to be moving up to at least a 3600 stall though. The smaller diameter of the converter really helps it get to speed quicker. I would reccomend at least a 3200 with a cam that size and a smaller diameter if you can. I got my converter from COAN.
Old Mar 4, 2004 | 11:02 PM
QCKZ28's Avatar
if i were to go with a 233/239 or GM847. my PI 2800 9.5" TC would be a tad on the small side, but should work well, just not optimal....
thanks
jesse
Old Mar 5, 2004 | 12:26 AM
1982z28with18s's Avatar
thanks
jesse
Bigger cam? Get some numbers and times with that came 1st.
Old Mar 5, 2004 | 01:09 AM
atljar's Avatar
Jesse-
How long you had that stall? Many times you can get a free restall or two with the first year or two of ownership.
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
ChrisFrez
Mar 22, 2015 07:00 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
ChrisFrez
Nov 30, 2014 08:41 AM
