MAF Problem?
Old Nov 8, 2003 | 08:26 AM
TArider21's Avatar
Question MAF Problem?
Will a malfunctioning maf sensor cause hard starting?
Old Nov 8, 2003 | 12:37 PM
Josh-'04 GTO's Avatar
Nope. If I'm not mistaken, there are cold and hot start tables preprogrammed into the PCM. It doesn't rely on MAF input to start the vehicle.
OBE1 95Z28's Avatar
If your MAF is bad, it will throw a code...have you had your car scanned for error codes? I'd start there. You can unplug the MAF and the car will start and run in speed density mode. Why do you suspect the MAF?
Old Nov 8, 2003 | 05:50 PM
TArider21's Avatar
Question Hard Starting
I suspect the MAF because it sounds like it is gasping for air sometimes when I start it. It has been hard starting for about eight months now. Funny thing is when I go to start it in the morning some- times it cranks right up. I was also leaning towards a bad fuel pump relay or something like that. It hasn't let me down yet, except for the time my ignition coil went bad, but other than that it has started everytime, although it may take a few tries.
Old Nov 8, 2003 | 11:17 PM
OBE1 95Z28's Avatar
The MAF doesn't restrict air, it just measures the amount of air drawn into the motor. Are you due for a tune-up? How does it run once you have it started?
Peytons'z
May 6, 2021 09:25 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
3TAS4ME
Apr 15, 2015 02:24 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
