Maf Bad???
Old Apr 20, 2005 | 11:21 PM
FORD_IMPORT_HATER's Avatar
Maf Bad???
This afternoon before I shut the MARO off I unpluggd the MAF to see if it was functioning correctly. I had recent problems with hard start issues as well as the engine shutting off almost immediately after it fires up. Once warmed up it runs with a miss but will not shut off. So anyways, I disconnected the MAF to see if I have any sudden changes. The engine still ran the same with no changes after disconnecting the MAF. I then plugged it back in while the engine is running and still no changes. Could my MAF be bad. I also have a SMALL tear on the elbow before it goes into the TB. Could this be the conclusion to my hard start troubles troubles?
Old Apr 20, 2005 | 11:25 PM
turbo_Z's Avatar
Re: Maf Bad???
Try closing that tear with some duct tape and see if that helps your problem. Usually when you unplug the MAF, the motor will stall out or may stall hard for a second and recover... either way you should notice the change.
Old Apr 20, 2005 | 11:31 PM
Re: Maf Bad???
There is no change whatsoever when I disconnect the MAF. If I fix that tear, would the MAF respond when being disconnected while the engine running?
Old Apr 20, 2005 | 11:48 PM
oneslowz28's Avatar
Re: Maf Bad???
i unpluged mine while it was running one time and it stalled bad realy bad i thought i f'd it up. i wouldnt restart untill i plugged the maf back up.
turbo_Z's Avatar
Re: Maf Bad???
Thats kinda what I am wondering too.
Old Apr 21, 2005 | 12:07 AM
Re: Maf Bad???
Thanks guys.
Old Apr 21, 2005 | 09:07 PM
Re: Maf Bad???
I was thinking... When I disconnected my MAF while the engine is running there was no change. I still have my MAF disconnected. I noticed that when I went to start the engine this morning, it still gave me hard start however, the engine did not stall or shut off. In conclusion, I think that the MAF is functioning properly but the tear in the elbow is whats giving me problems. This may also be giving me a hard start. Correct me if I'm wrong.
Peytons'z
May 6, 2021 09:25 AM
SpeedJunkee
May 3, 2015 08:49 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
