MAF Airflow
Old Dec 27, 2003 | 08:02 AM
TArider21's Avatar
Question MAF Airflow
How much air is the Mass Air Flow sensor supposed to flow at idle? Mine is around 7-8 gr/s, I was wondering if that is to low. Also, it makes a very loud suction sound, is it supposed to do this?
Old Dec 27, 2003 | 02:34 PM
You might want to read this document.
At idle, the air mass flow will range from as low as 6gps to as high as 10gps. If you reading is suspiciously low, you may have a vacuum leak. If it is suspiciously high, and the idle speed is correct, it's most likely a "faulty" or "miscalibrated" MAF. This problem is typical of "home ported" units.
Sounds like yours is "normal".
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
