Maf ?
Old Aug 26, 2010 | 09:47 AM
ray396's Avatar
Cool Maf ?
Hi, I have 95 camaro z28, with a 383 and a4. I am having problems with the idle to 2000 RPM. I am running a little lean by the BLM's. so I increased fuel pressure to 50psi. OK run's better, I had stock MAF laying around, so I removed the screen and cleaned it. I just wanted to see if it would make a difference, so I switched the Granatelli MAF, and I noticed the throttle response was much better. I put the fuel pressure back to 44psi. It seem seems be running fine now. I am in the process of hooking up a wideband. I will see how the blm's are. Was wondering if MAF could make that much of a difference? Thanks Ray
Old Aug 26, 2010 | 10:41 AM
87DJP2001's Avatar
Using the crap Granatelli maf will make any engine run rough. You just proved it with the switch to the stock maf.
You are lucky you didn't screw up stock one by removing the screen and had to continue with the Granatelli maf.
Old Aug 26, 2010 | 01:17 PM
ray396's Avatar
Cool
So they are crap, that is the first and last one. what is a good brand?
Old Aug 26, 2010 | 01:37 PM
87DJP2001's Avatar
Just continue to use the stock one. Its air flow is more then enough for a 383.
Old Aug 26, 2010 | 03:13 PM
ray396's Avatar
Cool thanks
OK, Thanks for the help, guys.Ray
Old Aug 26, 2010 | 06:12 PM
Granatelli.... tuning with the fuel pressure..... posting on Advanced Tech (wrong forum) - 3 mistakes.
Let's move this where it belongs
Old Aug 26, 2010 | 06:22 PM
ray396's Avatar
I have been a Bad boy
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
