Maf
Old Apr 9, 2003 | 05:46 PM
LT-1 Jeep's Avatar
Angry Maf
Anyone know of a easy test for the MAF on a 95 LT-1. I was told to disconnect the MAF, and if the engine died the unit was OK.. I was told if the engine kept running that the engine was in limp mode. Is this true?? I am running a factory MAF with no signs of damage to the inside, but the engine is sluggish.
Any suggestions of what to check??
Old Apr 9, 2003 | 06:01 PM
pu12en12g's Avatar
If you disconnect the MAF, the PCM goes into Speed Density mode.
I *think* you should also disconnect the battery to let the PCM relearn the tables, but I am NOT 100% on that...
Regardless, it should run the same, if not better, without the MAF... if it runs better without it, there could be a possible issue with the MAF.
http://web.camaross.com/forums/showt...hreadid=105060
Old Apr 9, 2003 | 06:09 PM
scoobysnax83's Avatar
mine doesn't run awful without it, but runs much better with it. If I disconnect it, the fans and SES come on.
Old Apr 22, 2003 | 06:59 PM
mineralwater's Avatar
i'd like to know as well!
I unplugged the MAf and ran the car - at part throttle, it pulled and sucked in my chest noticeably harder than it does with the MAF plugged in. Even after I cleaned the maf bars with a q-tip, I feel a bit more sotp with the maf unplugged.
What can this mean? I can unplug the MAF while my car is running - and the rpms will drop like its about to stall, then go back to 1000rpms.
I am thinking about just programming out the MAF in my pcm so I don't get the SES. what kind of a hit in mileage are we talking? Can't be much worse than the 12-14mpg that I get with the maf plugged in, right?
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
