Madz28 tune...
Old Aug 8, 2007 | 11:59 AM
raroz28's Avatar
Madz28 tune...
Anything else I should disable? I submitted the sheet to him already, but I can go back and change it...
Car Info
1997 Chevrolet Camaro
Gear Ratio - Stock for 97 6 speed car
Tire Size - 245/50/16
Transmission - T56
Thermostat - STOCK
Injectors - 30# SVO
Throttle Body - STOCK
MAF - Factory MAF Sensor
Headers - Mid-length
Cats - Eliminated
Nitrous - No nitrous
Rev limiter - tuner decides
Idle - tuner decides
Options
Powertune Selected.
Disable Speed Limiter.
Disable Skip Shift.
Disable AIR.
Disable Rear O2s.
Disable VATS.
Disable Traction Control.
Disable CPS codes.
Should I disable the EGR? A/C codes? Carbon canister codes? Should I have just disabled all the BS stuff? I don't have emissions here.
And I know I should have gone obd1 but I didn't think about it until recently and I got my spare obd2 a long time ago.
Old Aug 8, 2007 | 12:06 PM
indirocz28's Avatar
Car Info
Transmission - T56
Thermostat - STOCK
Injectors - 30# SVO
Cats - Eliminated
Options
Powertune Selected.
Disable Skip Shift.
Disable AIR.
Disable Rear O2s.
Disable VATS.
Disable CPS codes.
You can leave the EGR on , It doesnt affect anything and actually keeps combustion temp's cooler.
Old Aug 8, 2007 | 12:13 PM
2000GTP's Avatar
Do you plan on ever removing any of those systems? If not, then just leave the settings in place.
Old Aug 8, 2007 | 03:02 PM
JoeliusZ28's Avatar
just a question, what is CPS?
Old Aug 8, 2007 | 03:25 PM
raroz28's Avatar
crank position sensor
Old Aug 8, 2007 | 08:39 PM
Texas_96_Z's Avatar
Didnt know one could tune out traction control? Hell, I woulda if i had known.
Old Aug 8, 2007 | 11:03 PM
mattybz28's Avatar
Get the fan temps changed for the 160 degree thermostat. Just buy one and change it. It's like 20 bucks.
My car runs about 200 with the 115 heat index in Charleston.
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
maybe2fast
Mar 16, 2015 11:59 AM
chuyz28
Jan 27, 2015 08:53 AM
94zLT1
Jun 23, 2004 01:45 PM
