Madz28 tune...
Madz28 tune...
Anything else I should disable? I submitted the sheet to him already, but I can go back and change it...
Car Info
1997 Chevrolet Camaro
Gear Ratio - Stock for 97 6 speed car
Tire Size - 245/50/16
Transmission - T56
Thermostat - STOCK
Injectors - 30# SVO
Throttle Body - STOCK
MAF - Factory MAF Sensor
Headers - Mid-length
Cats - Eliminated
Nitrous - No nitrous
Rev limiter - tuner decides
Idle - tuner decides
Options
Powertune Selected.
Disable Speed Limiter.
Disable Skip Shift.
Disable AIR.
Disable Rear O2s.
Disable VATS.
Disable Traction Control.
Disable CPS codes.
Should I disable the EGR? A/C codes? Carbon canister codes? Should I have just disabled all the BS stuff? I don't have emissions here.
And I know I should have gone obd1 but I didn't think about it until recently and I got my spare obd2 a long time ago.
Car Info
Transmission - T56
Thermostat - STOCK
Injectors - 30# SVO
Cats - Eliminated
Options
Powertune Selected.
Disable Skip Shift.
Disable AIR.
Disable Rear O2s.
Disable VATS.
Disable CPS codes.
Car Info
Transmission - T56
Thermostat - STOCK
Injectors - 30# SVO
Cats - Eliminated
Options
Powertune Selected.
Disable Skip Shift.
Disable AIR.
Disable Rear O2s.
Disable VATS.
Disable CPS codes.
Car Info
Transmission - T56
Thermostat - STOCK
Injectors - 30# SVO
Cats - Eliminated
Options
Powertune Selected.
Disable Skip Shift.
Disable AIR.
Disable Rear O2s.
Disable VATS.
Disable CPS codes.
You can leave the EGR on , It doesnt affect anything and actually keeps combustion temp's cooler.
