madman alternator reloc. bracket
Old Nov 21, 2007 | 02:42 PM
reamo04's Avatar
alright, i know it moved the alt. to where the AC normally is, but does it allow you to retain power steering, or does it delete that as well?
Old Nov 21, 2007 | 02:44 PM
FASTFATBOY's Avatar
Alt only, flushes all other acc
David
Old Nov 21, 2007 | 02:53 PM
reamo04's Avatar
dang, do you have any idea where theres a bracket that will retain power steering? Its a street car, so i need power steering, but i also HAVE to have the alt. moved
Old Nov 21, 2007 | 03:01 PM
thesoundandthefury's Avatar
Zoops makes a billet P/S bracket that bolts to the lower driver's side of the block. I own this bracket but my engine build plans have changed in such a way that I can no longer use it. If you're interested, PM me. I can show you how to set it up using the Madman bracket.
Old Nov 21, 2007 | 04:37 PM
There's a post on here from someone who deleted the A/C compressor, then moved the alternator to the A/C compressor position, and used an idler pulley where the alternator used to be. Doesn't provide a lot of "wrap" on the relocated alternator pulley, but he indicates it works OK. Try a "search"
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
War Engine
Sep 18, 2015 07:28 PM
