Made an in-car valve spring removal tool pics w/in!!
Re: Made an in-car valve spring removal tool pics w/in!!
Originally Posted by flyinZ
i hate to bring up an old thread like this, but did anything ever become of this tool??
How would you keep the valve from dropping down?
Originally Posted by 1racerdude
Ya put air in the cyl while ya do it.Some say they won't fall out with the piston at TDC. I won't trust that.It could fall far enough to bend when ya try to get it back up by rotating the engine.
As long as your valve stem seals are OK, you could even do this part alone, without another person holding onto the valve stem for you (since it wouldn't slide)... but it would probably take a lot longer.
As for this tool, I saw a comp cams tool, which was nearly identical, only I thought it worked on both springs (intake & exhaust) at the same time.. I could be wrong about that part.. but it definetly was wider than this tool..
Ya, I've done the (air in the cylinder) before, but on two of my spark plug holes, I dont have access to them with the air fitting/hose...(damn Dynatech LT's)...I've thought about just using a magnet, and some string to tie the valve off..The rest of them, are ok to get to...
oldschool
Feb 9, 2016 09:21 PM
