Made an in-car valve spring removal tool pics w/in!!
Old Jan 25, 2004 | 10:48 PM
Camaro90RS's Avatar
Last week, I took some measurements for a valve spring removal tool to be used on the car. I have read about many people having problems with the lever type so I came up with this. It is made of 3/8 thick AR plate, (very strong stuff), and was rough cut with a computer controlled plasma cutter. We then drilled the hole in it, and then milled a recessed area on the bottom side that is 1.50" wide so that the tool does not slide off the valve spring while compressing it. I just got a 7/16' threaded rod, and some grade 8 nuts. All you need to do is remove the stock studs, install this stud and then use a 1/2" ratchet and tighten the nut down. You could also use an air ratchet for even faster times. Look at the links below for some pictures of the tool.
http://groups.msn.com/BriansFbodyPic...to&PhotoID=111
http://groups.msn.com/BriansFbodyPic...to&PhotoID=112
http://groups.msn.com/BriansFbodyPic...to&PhotoID=113
http://groups.msn.com/BriansFbodyPic...to&PhotoID=114
http://groups.msn.com/BriansFbodyPic...to&PhotoID=115
http://groups.msn.com/BriansFbodyPic...to&PhotoID=116
http://groups.msn.com/BriansFbodyPic...to&PhotoID=117
The tool works great so far, but I havent had a chance to use it on my car personally since its in storage. Tell me what you think of it.
Brian
Old Jan 25, 2004 | 10:53 PM
LS1_03's Avatar
Very nice and easy to use. I went over and personally used it. If you've never changed springs before(which I haven't), it's cake.
Old Jan 26, 2004 | 07:15 AM
thermwood1's Avatar
I don't guess you'd be willing to share all of the dimensions, would ya?
Old Jan 26, 2004 | 07:18 AM
Camaro90RS's Avatar
I dont think I will share them, yet anyway. I thought about talking to my friend at the steel working shop and ask him about making a few more of these and sell them. I guess I need to make a phone call.
Brian
Old Jan 26, 2004 | 07:35 AM
ibanez6rg's Avatar
Not a bad design.
Old Jan 26, 2004 | 07:39 AM
Ryan94Camaro's Avatar
You can already buy an IDECTICAL tool just about anywhere. They are not hard to make.
Old Jan 26, 2004 | 12:07 PM
Camaro90RS's Avatar
Hmmm, guess you live somewhere that there are autoparts stores on every corner . I have only seen one person on LS1tech.com sell ones like these and thats the only place. All the ones I have seen in stores are the lever type. I didnt make it to sell it, I just made it for my own use on my car and several others. They are kinda hard to make when you have to use a milling machine, and a plasma cutter to cut this material with. This isnt your average mild steel you can buy at Joe Blow's hardware store . I was just sharing the part I made incase anyone else wanted to give it a try.
Brian
Old Jan 26, 2004 | 12:26 PM
Don't get me wrong, its an awesome design and does work VERY well. I guess I'm just too used to having access to the tools required to make stuff like that.
Old Jan 26, 2004 | 03:46 PM
Camaro90RS's Avatar
I understand that, my main focus in posting this was to show other people an idea for changing springs easier. I have read alot of posts where people dont like the lever type with our engine compartments, and this is a much better solution. Having access to these tools is very nice, but not everyone has the access like you and me .
Brian
Old Mar 23, 2004 | 05:44 PM
blown383's Avatar
Any updates on this tool? I need to swap springs soon!
-B
Old Mar 23, 2004 | 08:44 PM
Bud M's Avatar
Its a great idea, but it would be even better if it worked on the rocker stud...
Nice work, though!
Old Mar 23, 2004 | 09:06 PM
ibanez6rg's Avatar
Nice work, though!
Don't see why it wouldn't?
Old Mar 23, 2004 | 09:18 PM
95 Silver TA's Avatar
Dude,
That design is so simple that it IS Brilliant. VERY NICE!!
Thx,
Claude
Old Mar 23, 2004 | 09:32 PM
Camaro90RS's Avatar
Thanks for the compliments guys!! Actually the tool does work pretty well. Only problem that I had was the hole for the stud to go through wasnt quite large enough. I mean it worked, but it occasionly got stuck on the threads. Not a big deal, but I know what I have to improve on. It would actually work best if the whole was actually a slot.
It will work on the rocker stud if you happen to have a fine thread nut either in 5/16 for stock or 7/16 for aftermarket studs. I just used a short section of coarse 7/16" rod with a couple of grade 8 nuts. When I go to use it again in a few weeks, I am going to use some grade 8 threaded rod though.
Overall the tool works great, and I was a bit surprised to see this thread come back to life.
Brian
Old Mar 23, 2004 | 10:22 PM
Green95Z28's Avatar
Great design!, posting pics kinda gave it away though!
I want one! This would be AWESOME with an air-ratchet!
