Mac Headers on 95
Mac Headers on 95
I'm wondering if anyone with a 95 who installed mac headers had to buy extensions for the o2 sensors? And if so do i need an extension for pass and driver and how long? Also do i need square or flat connectors?.
One more question will i be able to install these headers with my car just on a a set of stands or will i have to have it higher up?
Thanks for any help you can give.
Re: Mac Headers on 95
When I did mine the passenger side o2 reached fine. But the drivers side would not reach, so for a clean install I would suggest an o2 extensions on the drivers side. Since I was cheap instead of buying an extension all I did was cut the harness so the wire had more slack, after a little persuading there was just enough slack to get it to reach. I believe you can find the right extensions on Thunder Racing's site. And yes jack stands is all you need.
Aug 24, 2015 06:41 AM
