M22 DRain plug
Old Feb 23, 2004 | 04:45 PM
SLeeper94Z's Avatar
M22 DRain plug
does anybody know where I can find a m22 drain plug , ive tried autozone,napa,Advance, I was going to go to loews store and jus get a bolt that same size as the drain plug does anyone know the size? thanks
Old Feb 23, 2004 | 04:47 PM
fastcamz28's Avatar
NAPA is where I get mine. Autozone and the rest didn't have them. At least that is the situation in Dallas. Good luck!
Old Feb 23, 2004 | 04:50 PM
Hyperspeed97z28's Avatar
NAPA does carry them...
Make the guy find it for you..
They are so lazy
bigde4u's Avatar
carquest is where i finally found mine at!!
Old Feb 23, 2004 | 05:18 PM
JasonL's Avatar
Have you considered asking the dealer? They sold me a replacement magnetic drain plug for my car, which came with a regular plug.
I've seen some of the aftermarket plugs, and the one from GM is higher quality IMHO.
Old Feb 23, 2004 | 06:31 PM
Brandon 95 Z28's Avatar
I got mine from napa as well, they are a rip off tho, like 9 bucks each
Brandon
Old Feb 23, 2004 | 06:33 PM
fastcamz28's Avatar
In Dallas, they were about $2.00, so yes, you got ripped! That sucks!!!
Old Feb 23, 2004 | 10:59 PM
twdz28's Avatar
Yea Napa guys are lazy. To find this drain plug they have to look in the book at least thats what they had to do for me. And they where the only place that had them. Oh and to the other guy this is not a drain plug for the oil pan it to block of the air pump fitting on headers so you can remove all that crap.
Old Feb 24, 2004 | 11:47 AM
Fbody1's Avatar
I got mine at napa, but I had to tell them it was for a bmw( drain plug) and then they found it me one , was 7.99
Old Feb 24, 2004 | 12:29 PM
Stock Z's Avatar
I don't think you can just use a bolt because the threads are different. However, I used brass plugs (like used for plumbing) from any hardware store, the threads where still off but I forced them in. The brass is soft enough that I could cross-thread them and make a tight seal and they where cheap (I assume you are using them to plug the holes in exhaust manifolds from the AIR fittings). Just something else to think about.
Old Feb 24, 2004 | 01:17 PM
TUFF LT1's Avatar
None of the chaiin stores here in DE had them I had to go to a local "kunkles" autoparts where they could have them in a day. The dealership said that they could get me some in a day or two but at 30 some dollars a crack I passed their offer right up!
Old Feb 24, 2004 | 01:28 PM
ibanez6rg's Avatar
Napa has them.
KYWes
Jun 14, 2022 06:52 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
