DMH E- Cutout (kind of long)
Old Feb 24, 2004 | 06:36 AM
IXLR894Z28's Avatar
I'm trying to get this installed on my car, and of course in the lovely state of VA the electric part is illegal, no problem. I have them install everything except that part (even ran the electrical work) and I will put the electric part on myself. Now they are telling me that the nuts that hold it on will not come off once installed, and I need it off during vehicle inspection time (once a year). Is this true? I have to have it inspected with the cap in place to pass.
Old Feb 24, 2004 | 09:11 AM
95 Mystic TA's Avatar
Re: DMH E- Cutout (kind of long)
Originally posted by IXLR894Z28
that the nuts that hold it on will not come off once installed, .
Did they say why? I'm guessing they are going to be "sunk" into the "stud holes?"
Old Feb 24, 2004 | 09:38 AM
fastcamz28's Avatar
I have a DMH unit and I don't believe that's true. You should be able to remove the motor anytime you choose. It simply bolts on to the cutout, much the same way a standard cover does, w/ bolts and nuts. That would not make sense that once you installed the motor it could never be removed....
Thanks!
Old Feb 24, 2004 | 11:39 AM
IXLR894Z28's Avatar
You know the special nuts that come with the unit to reach the studs through the machined aluminum, those are the ones he said are permanent, I also disagree, but I wanted to be sure. thanks
Old Feb 24, 2004 | 12:49 PM
JSK333's Avatar
It sounds like Dave is still using the same nuts as I have on mine, in which case, yes, they are removeable. They are a locking style, meaning they won't vibrate off, but they'll come off with a socket wrench.
Old Feb 24, 2004 | 01:30 PM
IXLR894Z28's Avatar
Thank-you. now I'm putting this thing on.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 7, 2015 03:01 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
stanghunter211
Aug 29, 2002 03:04 AM
