m.a.p. sensor
Old Jun 18, 2005 | 09:57 AM
flounder564's Avatar
m.a.p. sensor
how to check and clean the m.a.p. sensor
Old Jun 18, 2005 | 12:01 PM
Kataklysm's Avatar
Re: m.a.p. sensor
Don't touch it. Once the car has a problem is when you start touching things.
Old Jun 18, 2005 | 02:15 PM
Re: m.a.p. sensor
You check it by looking at the output signal voltage under known operating conditions.... at idle, should see about 1.15V. With key on engine off, should read very close to 5.0V, depending on your local barometric pressure (significantly less in high altitude locations like Denver).
Do not try and clean it. Its a fairly sensitive strain gauge. There's no reason is should get dirty, it isn't exposed to anything other than clean air. More common problem is a dried and rotted seal, or a dried and cracked harness connector.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
