AS&M Headers Questions
Old Aug 23, 2004 | 01:54 PM
  #16
WS Sick's Avatar
Re: AS&M Headers Questions
You'll need the headers for 94-95, the single cat, and a place to weld a pipe from the back of the cat to the present cat-back, You could buy the I pipe for a single cat-car, ( I beleive you can order them as replacements from most of the companies that make cat-backs), a set of O2 simulators will simplify things, but you can delete them out with a computer tune.
Old Aug 23, 2004 | 02:19 PM
  #17
Johnnynsac's Avatar
If you want the AS&M's, tell the exhaust shop you want a single high flow cat put in place of the dual cats. Thats what I did. Mines a 97 also. I lost some torque down low but it does shine up top. Believe me, once these are on, it's all worth it.
Old Aug 23, 2004 | 02:55 PM
  #18
Loadre's Avatar
Originally Posted by 1970AAR
Would it be cheaper/and or more effective to just buy the AS&M headers for single cat cars and fab up a true dual exhaust sys. with an X pipe for my car rather than buying the "package" with the dual cat Y?
Yes it would be cheaper.
Johnnynsac,
Trust me, you didn't lose any bottom end torque.
Old Aug 23, 2004 | 03:00 PM
  #19
According to some other members on the board, it would not be a good idea to run single cat AS&M's through dual cats....So thats why I want to convert to a single cat setup so I can run the headers.
Besides....
99-HDRPKG-SD Random Tech Stainless Steel DualCat Y-Pipe, Arizona Speed & Marine 1-3/4" Headers, Full Accessory Package for 1996-1997 model cars $1459.00
There's gotta be a better bang for the buck high performance header out there now If not, tell me if you think this purchase is really worth it.
I'm not sure who "some members" are, but I'm pushing 800HP through the single-cat AS&M's. They were modified to bring the drivers side collector straight back, and by adding length to the passenger side collector. Then dual 3" CarSound high flow cats were connected to each modified collector, and a 3" custom Y-pipe built by Mufflex, to connect to a 4" Mufflex catback. It worked VERY WELL, as determined by engine vs. chassis dyno testing.
http://members.aol.com/InjuneerZZ/im...hotos/Dyno.jpg
My AS&M's were originally used on a 30th SS convert, making about 850flywheel HP, 383/Vortech S/C setup. At that power level, the engine was dyno tested to compare the AS&M's with Hooker LT's, and the AS&M's put down SUBSTANTIALLY more power (remember, this is a setup that only ran in the 5,000-7,500rpm range, at the track). It was only when they bumped the cam and pushed the engine over 900HP that the Hooker LT's made more power than the AS&M's.
I currently run the AS&M's with Borla XR1 shorties on each collector, and a 3" pipe back to the axle, with a 90deg turndown.
http://cjcfo.fbody.com/members/injun.../DCP03675a.jpg
Old Aug 23, 2004 | 03:04 PM
  #20
1970AAR's Avatar
Is that street legal?
Old Aug 23, 2004 | 03:05 PM
  #21
5.0THIS's Avatar
Hooker long tubes are overrated.. been saying it for years
AS&M>Hooker LT
Old Aug 23, 2004 | 04:02 PM
  #22
Loadre's Avatar
I think Injuneer's emissions laws changed so he can't drive the car on the street much at all anymore regardless.
Old Aug 23, 2004 | 04:19 PM
  #23
It is if this is how it goes "down the street".....
http://cjcfo.fbody.com/members/injun.../DCP03428b.jpg
Old Aug 24, 2004 | 08:25 AM
  #24
GrnHornet's Avatar
Hey 1970AAR,
I emailed AS&M this is the guy I talked with Here is what he had to say.
Thats correct, $650 coated. I will sent the correct emissions tubes with
them.
Ben Benavides
www.azspeed.com
Phone: (480) 753-0208
Fax: (480) 753-0216
-----Original Message-----
Sent: Friday, August 13, 2004 5:22 AM
To: Ben Benavides
Subject: RE: 96-97 headers
Thanks for the info. Couple of more questions though. Will I have to
modify the emissions tubes to run these on my car or is it a direct
fit? Also that's 650.00 with the coating on them right?
Kenneth
Sent: Thursday, August 12, 2004 5:39 PM
To: K
The headers we have for the 94-95 Camaro's will work with the 96 and
97's.
You will have to delete our y-pipe that works with the earlier singe cat
setups and go with a Random Technology y-pipe with cats that will tie
our
headers to your cat-back exhaust. The headers are 650 without the
y-pipe.
The Random Y-pipe with cats is 650 as well. Both of these prices do not
include shipping. Let me know if you have any other questions.
Ben Benavides
www.azspeed.com
Fax: (480) 753-0216
Sent: Thursday, August 12, 2004 11:19 AM
To: Ben@AzSpeed.com
Subject: 96-97 headers
Hey Ben,
I have a 1997 Z28. I was wonder do you offer a long tube header
for us 96-97 guys without the y pipe or with dual cat y pipe? If so
can you tell me what the price would be.
Kenneth
Old Aug 24, 2004 | 08:30 AM
  #25
GrnHornet's Avatar
What I got from it is that you can fab your own dual cat Y pipe and it should work just fine. He suggested the Random Tech y-pipe as a suggestive sale. I plan on getting these which are actually mids and fabbing my own dual cat y pipe.
Old Aug 24, 2004 | 09:05 AM
  #26
WS Sick's Avatar
What is the Primary tube length of the AS&Ms?, what is the collector dia and how long are they?
Old Aug 24, 2004 | 10:50 AM
  #27
1970AAR's Avatar
Hey GrnHornet, thanks alot for that info...I see the Random Y-pipe is REAL expensive...but it does include the cats. Also, when you meantion "emissions tubes" what are those specifically?
Old Aug 24, 2004 | 11:03 AM
  #28
WS Sick's Avatar
The tubes for the AIR system and the EGR system that plumb into the headers.
Old Aug 24, 2004 | 01:24 PM
  #29
2MCHPSI's Avatar
If you do decide on single cat setup, look into Rk SPort 1/ 3/4 headers . They are almost identical to AS@M (same exact design and manufacturer) and are also great quality for at least 100-150 bucks cheaper.
I have used both AS@M and RK Sport inthe past, and there is no noticable difference between the two but price.
Old Aug 24, 2004 | 01:42 PM
  #30
GrnHornet's Avatar
No problem 1970AAR. The emissions tubes are exactly what WS Sick said. I agree with you the Random Tech Y pipe is a sickening price to pay.
WS Sick I the primaries are 1 3/4 like a long tube and I believe the collectors could be 3". I'm not sure on that though. 1 3/4 primaries is one of the reasons i am choosing it over Macs. They have 1 5/8 primaries.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
