Lunati Timing Set.. OEM Replacement???
Old Apr 14, 2003 | 06:59 PM
n2ceptor's Avatar
Question Lunati Timing Set.. OEM Replacement???
In the new Summit cat.. pg 192 Lunati Timing Set for LT1 p# LUN-93094 is this a direct replacement for your OEM or is it like the Cloyes???
93Z Will
Old Apr 14, 2003 | 08:09 PM
Don 97 SS's Avatar
Re: Lunati Timing Set.. OEM Replacement???
93Z Will
You might want to contact Summit or Lunati's tech line for more info on that set.
Have you tried the GMPP LT1/LT4 Extreme Duty timing set that works well? That is what I would recommend.
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
TitoPR221
Jan 2, 2015 03:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
