Lunati or GM timing chain on cam install??
Summit has the GM Performance parts LT1 extreme duty set for $240 bucks. Lunati has their set for $110. The price of the Lunati just makes it seem like the way to go. Wondering if anyone knows if they both come with the same hardware or not? The GM one lists everything I'd need but the Lunati just say's stuff about the timing chain itself. Does it come with everything also? On top of that do you think the strength of the Lunati is up to par with the GM version? Thanks in advance.
Did you search? I have not seen much of anything good said about the Lunati set. Don't know about the truth in it.
If you don't post some info (like at least the year of car) you may get some wrong/bad info or advice.
Oh yeah that would probably be a good idea. I did do a search and didn't come up with much. Car is a 95 Z with simple mods. CAI,Cutout,LT's,Vig. 3000rpm,3:73's,Trans-go,and some other minor stuff.
