Lunati cam specs
Old Jun 10, 2004 | 06:49 PM
jbbiggs's Avatar
Lunati cam specs
I aquired a lunati cam and cannot find specefics for it,
Stampings on the end are as follows
95 up
n4lp
113
rra1-224-234
By my measurements the lift is
.478
.499
I am assuming the larger lobe is the intake but I am not 100% sure
Just curious if this is a NA, o2, or forced induction cam
Old Jun 10, 2004 | 08:45 PM
Camaro_Maniac63's Avatar
By looking at those numbers, it looks like the duration is 224/234 (probably at .050") and the LSA is 113. And with that much split between the intake and the exhaust, it is very likely that it is a nitrous or a FI cam. The smaller number is the intake duration, by the way.
Old Jun 11, 2004 | 06:31 PM
jbbiggs's Avatar
I think the intake lift is the smaller of the two, does this sound right for a forced induction cam?
Old Jun 11, 2004 | 06:39 PM
Yes, the smaller number is probably the intake lift, and yes, that looks very much like a FI/nitrous cam Are you gonna stay N/A or do you plan on going FI?
Old Jun 11, 2004 | 06:46 PM
jbbiggs's Avatar
Nay on the FI, and no No2 either, NA all the way
I would like a cc305 or cc306 or something close
Old Jun 11, 2004 | 06:48 PM
Yeah, then you might want to look into different cam. Good luck.
Fastbird93
Apr 9, 2016 07:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
SpeedJunkee
Jan 14, 2015 05:34 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
