Lunati cam specs
Lunati cam specs
I aquired a lunati cam and cannot find specefics for it,
Stampings on the end are as follows
95 up
n4lp
113
rra1-224-234
By my measurements the lift is
.478
.499
I am assuming the larger lobe is the intake but I am not 100% sure
Just curious if this is a NA, o2, or forced induction cam
95 up
n4lp
113
rra1-224-234
.478
.499
By looking at those numbers, it looks like the duration is 224/234 (probably at .050") and the LSA is 113. And with that much split between the intake and the exhaust, it is very likely that it is a nitrous or a FI cam. The smaller number is the intake duration, by the way.
Brandon Wittmer
Dec 20, 2014 09:51 PM
Are you gonna stay N/A or do you plan on going FI?
