Lube or sealant? (rocker studs)
Old Jan 27, 2004 | 05:13 PM
ibanez6rg's Avatar
Not sure if they touch coolant or not.
Old Jan 27, 2004 | 05:31 PM
Red_94Formula's Avatar
No they dont go into coolant. I simply screwed mine on with out anything.
Old Jan 27, 2004 | 05:54 PM
Brandon 95 Z28's Avatar
I just used a little ARP sealant on mine, because lloyd recommended using selant on the intake studs because he mentioned the threaded holes will be exposed to the intake ports after porting, but I used a lil sealant on them all, partly because one of my friends kept coming loose. I then torqued them all down to 50 ft lbs.
Brandon
Old Jan 27, 2004 | 06:04 PM
ibanez6rg's Avatar
Guess they would need to be torqued with the heads on, eh?
Old Jan 27, 2004 | 06:11 PM
LOL, i did it with the heads off for room, and it wasnt the easiest task to keep the head from moving while torquing it down, but thats what we have fathers for, to hold things in situations like that
Brandon
Old Jan 27, 2004 | 07:11 PM
ibanez6rg's Avatar
I had to use the impact wrench to get the stock studs off. There was no way in doing it with a breaker bar and a head bolted to nothing.
Old Jan 27, 2004 | 07:13 PM
Yeah i had to use a 24" breaker bar, and have two people hold hte heads steady for me to remove the stock studs.
13qtr
Oct 28, 2016 08:11 PM
magman
Apr 15, 2016 03:08 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
