lts leave any o2s?
lts leave any o2s?
when I installed my jet hots I removed the o2s it's a 1996.Should I have left them? I also removed cats and air pump. will this make the car run lean? low power?
p.s. how do I use spell check on this forum? thanks
Re: lts leave any o2s?
Which O2s did you take out? Hopefully not fronts...
For back ones, you'll need o2 simms in place of them.
Air pump might throw codes but can be programmed out.
BTW, you'll need the front O2s to keep your car from losing it's mind when it goes closed loop. The back ones just monitor the performance of the cats. No cats=ses w/out o2 simms.
Originally posted by shoebox
Gotta have front O2s.
Kevin
WobblySausage
Oct 7, 2015 10:09 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Bails098
Aug 17, 2015 05:15 PM
Aug 17, 2015 09:50 AM
