LTCC Wiring Question
Old Jan 31, 2006 | 07:58 AM
93ZM6Tally's Avatar
For you all running the LTCC. What did you do with the yellow wire (Used for the two stage timing retard), did you just leave it not connected, ground it, or connect it up. I won't be using the delay circuit now, but do have plans for it in the future.
Thanks,
Mark.
Old Jan 31, 2006 | 11:52 AM
djw's Avatar
djw
Re: LTCC Wiring Question
I left it unconnected. Just coiled it up and taped it inside the shielding with the rest of the wires.
Old Jan 31, 2006 | 01:28 PM
FatalZ28's Avatar
how do you like your setup? i plan on getting one for my car and want to hear opinions from people who have them.
Old Jan 31, 2006 | 01:46 PM
djw's Avatar
djw
I really like it. The ignition is noticeably smoother, and the installation was a snap.
Old Jan 31, 2006 | 02:29 PM
93ZM6Tally's Avatar
Where did you mount your box? I've looked at most documented mounting options, but I'm always looking for other possible mounting locations.
Old Jan 31, 2006 | 05:56 PM
BLDun's Avatar
I also did not use the yellow wire. Just rolled it up and taped it off. I mounted the box on the driver's side fender well toward the front little. I mounted the coils on the valve covers. If you would like a pic let me know and I will email you one. I really like my setup. I replaced my opti at the same time - the old one got really soaked one day - and I can really notice the response difference.
Old Jan 31, 2006 | 06:12 PM
dreamer1q's Avatar
I mounted mine on the driver side inner fender, and mounted the coils under the car.
One bit of advice. When you get it, take the top off and drill a hole over the red and green lights in the box. Then take some weatherproof silicone and glue a piece of clear plexiglass over the hole. Makes checking for codes a hell of alot easier
Old Jan 31, 2006 | 07:24 PM
93ZM6Tally's Avatar
Good tip I like it. I'm mounting mine on the driver side frame rail near where the ABS unit was. I'm also fabbing up a heat shield just for extra insurance. With the harness it's going to be difficult to make it a "clean" installation. My coils are on mounted on some home made fuel rail covers made out of 1/8" aluminum sheet.
Old Feb 1, 2006 | 07:24 AM
djw's Avatar
djw
I mounted mine the same place, on the driver's side fender toward the front right up against the fuse block. I also mounted the coils on the valve covers. I bought LS2 coils off of ebay and they came with a bracket and wiring harness. So I used the brackets, I just had to modify the passenger side to accommodate the oil fill. Then I made a plate to bolt them to that I could us the valve cover bolts to hold them down. I also used the wiring harness (this cleaned the wires up a little), so I had to cut the LTCC wiring harness a part and modify it to match. I am really pleased how it came out. The wires are very clean and the coils are mounted uniformly, with very short plug wire runs.
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
lbrowne
Nov 13, 2011 04:25 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
