LTCC w/ MSD harness?
Old Mar 19, 2006 | 10:58 PM
CDE's Avatar
CDE
I am getting around to hooking up the LTCC and want to use my 96-97 MSD harness so I dont have to cut the stock wires up. If anybody has done this what wires go to what?
I have the white and the 2 pink wires on the LTCC end, and the MSD pack has 4 leads, black, red, orange and 2white.
Any body?
Clint
Old Mar 21, 2006 | 12:33 AM
CDE's Avatar
CDE
Re: LTCC w/ MSD harness?
Awww comeon, somebody bite on this.
Clint
Old Mar 21, 2006 | 12:36 AM
ramair96ws6's Avatar
what year is your car?
Old Mar 21, 2006 | 12:38 AM
CDE's Avatar
CDE
97 model
Old Mar 21, 2006 | 12:45 AM
Brettinator's Avatar
Any body?
Clint
Not hijacking your thread Clint, but I'm rusty here, MSD Harness? I have a MSD 6AL but that is going away with the LTCC, so what's a MSD Harness? Probably a dumb question. By the way what coils are you going to run? I decided on the new MSD LS1 coils w/Magnecor 10mm wires. Mine's a 97 too, building my own brackets but trying to see other ideas out there so I made a post your LTCC bracket post today, maybe post up your setup if you get time. Good luck and thanks. Oh yeah maybe if your good with the wiring you could give me so tips on redoing my setup since I had the MSD Blaster coil w/MSD6AL, already had to cut n splice just to get that to work. My LTCC will be here Thur p/Bob. Thanks, Brett
Old Mar 21, 2006 | 12:47 AM
2-pinks to red
white to white
check that the msd harness wires run back to those wire colors
the red should lead to a pink single wire and the white to a white wire
hope that helps
Steve
here is a few pics of my setup
http://web.camaross.com/forums/showthread.php?t=410811
Old Mar 21, 2006 | 12:56 AM
CDE's Avatar
CDE
Thanks a bunch Steve!!!! Helps alot!!
Yeah Normally the LTCC does do away with the coil/MSD but the harness is so I dont have to hack up my stock wires the MSD harness allready has the female connectors there so it makes it a little faster too.
Old Mar 21, 2006 | 12:58 AM
CDE's Avatar
CDE
Heres the link to the thread that has some pics of my LTCC brackets.
http://web.camaross.com/forums/showt...t=LTCC+install
Injuneer
Apr 25, 2022 06:22 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
canuck94z28
Aug 19, 2015 05:50 PM
88IROC_Z
Jul 22, 2015 11:38 PM
