loudmouth suggestions????
Old Mar 20, 2006 | 10:04 PM
robwin95z's Avatar
anyone with a 93-95 lt1 had this problem?? i ordered my loudmouth catback along with the extra s-pipe adapter (pn 30045). here's the thing, i also am updating to an off-road y and longtube headers. the s-pipe comes with a ball flanged end to hook up to the y, the pacesetter y pipe is not set-up to recieve it. what do i do? anyone got any pics of the connection that is required? thanks!!
Old Mar 20, 2006 | 10:11 PM
1quickTA's Avatar
Re: loudmouth suggestions????
If you got headers and an orp, I wouldnt think that you would need the adaptor. Off road y-pipes would be the same for any LT1 car, and therefore I would expect your exhaust to bolt right up. I have a '96, but by Pacesetter y-pipe bolted right to my SLP loudmouth before I got rid of it due to the overly loud exhuast. Have you actually tried fitting them or just thinking ahead?
Old Mar 20, 2006 | 11:01 PM
jbsupra89t's Avatar
You wont use the S on the LTs... it should be pretty close if not just bolt right up, or else a small bit of fabrication will need to be done. Good luck.
-J
Old Mar 21, 2006 | 04:52 AM
GONE's Avatar
because you have a single cat car, you'll need to take it to the muffler shop.
I have a Borla on my 95' and had the same issue. Dual cat cars 96/7 require little if any modification but the single cat cars require some fabrication.
I actually used a set of 3.5 inch collectors on mine as a joint so the exhaust could be remove in pieces if need be. I highly recommend it.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
