LTCC w/ LS2 coil packs and modified harness
Old Nov 24, 2005 | 01:22 PM
  #16
Vicious95Z28's Avatar
Re: LTCC w/ LS2 coil packs and modified harness
What's the difference between this and the Delteq? Obviously the coils are different but what;s the difference in how it works. Also I know that some LS1 guys were relocating their coils to under the cowl for a hidden appearence. Opens up for fancy valve covers and convenience. Just an idea. Folks always want options. We can prolly check the LS1 forum for details.. BTW. What's the price difference? I mean if you go the Delteq route and you opt for the pretty billet cover to replace the opti cap and rotor button which I would, You're in at over $700.
later,
Vicious
Old Mar 21, 2006 | 08:24 AM
  #17
Mikey97Z's Avatar
Steve, that looks totally awesome!
I have LTCC and LS1 coils and it looks like an octopus is attacking my engine!
Will your wire mod work with my LS1 coils if I get a mounting bracket?
Old Mar 21, 2006 | 09:24 AM
  #18
97SLPcamaroSS's Avatar
does anyone know if the 6.0 truck coils are the same as the gto's ls2 coil.
Old Mar 21, 2006 | 10:27 AM
  #19
ramair96ws6's Avatar
I dont see why it wouldnt wire is wire as far as the coils are concered.
this isnt that hard to do but it is a little time consuming
the most expensive part is the MSD connectors for the coil packs.
Steve
Old Mar 21, 2006 | 11:03 AM
  #20
The coils don't have to be visible from above on an LT1.....
Old Mar 21, 2006 | 11:20 AM
  #21
Chrisbequick's Avatar
I wish I would have seen this last year when the thread was fresh. This looks tike the way to go me. Did Steve get some pricing worked out for his wiring mod? I want to do this.
-Chris
Old Mar 21, 2006 | 11:13 PM
  #22
Here is the cost break down for the parts I use
MSD connectors-MSD-8185 $19.88 each you need 2
Msd coil harness-MSD-8877 $30.88
Wire loom from radio shack 5-6 bucks
electrical tape 3 bucks
crimp connector for ground 5 cents lol
Tools if you wanted to do it
MSD crimper-MSD-3505 $52.00
MSD Die for crimper-MSD-3510-$30.88
I could buy everything and do it for you for
$84.00 in parts after ship from summit
$10.00 for local pick up stuff (wire loom tape etc..
$100.00 to build (4-5 hours to build it and test it.)
175-200 bucks shipped should do it all and I would need you to send me your LTCC harness also
Steve
Old Mar 21, 2006 | 11:23 PM
  #23
96SilverRam's Avatar
Wow, great info !
Old Mar 22, 2006 | 12:16 PM
  #24
Shon Herron's Avatar
I like that set up better than the 8 individual connections, cleans it right up!!!
And really like the low mounted coils.
Old Mar 22, 2006 | 03:25 PM
  #25
97SLPcamaroSS your pm box is full i can not send you anything
Old Apr 3, 2006 | 08:29 PM
  #26
IN box is empty now
Old Apr 4, 2006 | 09:28 PM
  #27
Jeff H's Avatar
What did you need the MSD-8877 coil harness for, are you running an MSD 6A or something? What plug wires are you using in your setup?
Old Apr 6, 2006 | 08:42 AM
  #28
Loadre's Avatar
Looks very very clean. I'm getting ready to go LTCC and wish I had the extra cash to send to you to do this.
Old Apr 27, 2006 | 03:05 PM
  #29
bunker's Avatar
LOL just saw this doing a search for another car, I did the same thing a while back, thought I was the only one LOL Didn't like all the wires the LTCC came with, so I automatically took it apart and built the same harness.
The connectors for the LS1 coil harness you can pick up at a local junkyard. Just rip it off an 86-87 Buick 3.8L engine, it only has 1 but all the pins are the same and plugs right in, so if you find 2 buicks with that engine/year your'e set
Old Dec 16, 2006 | 11:31 AM
  #30
Highlander's Avatar
do you have a schematic of the conversion???
