LTCC & Plug Wires.
LTCC & Plug Wires.
I have acquired all of the parts necessary to install the Bailey LTCC ignition setup on my 97 Camaro Z28. Does anyone have a part # for the proper plug wires to use? Bailey's website . . .
http://www.bailey-eng.com/LTCC.html
. . . recommends Taylor Spiro-pro cut to fit wires (NOT ultra-low resistance type).
It is all going to depend on where you mount the coils. If you mount them on the valve covers like I did they wires will be very short - about 6" each - but if you mount them near the radiator shroud or the firewall the wires will need to be longer. Either way you will need to cut them to the length you need.
The setup I have will look almost identical to what is shown in the following picture:
http://www.bailey-eng.com/bracket%20...loryBillet.jpg
Still need a part # for wires. Anyone?
armedtrigger
Feb 24, 2015 08:30 PM
