LTCC is installed!
Old May 17, 2006 | 02:29 PM
Loadre's Avatar
LTCC is installed!
Took the car out last night after replacing the rear main seal and putting in the LTCC. The car has never run that good in the past 3 years. Didn't get on it yet because the rear main was still leaking like hell and already getting ready to pull the tranny again, just thought I would share this while I'm taking a break from the car.
Can't wait until tomorrow hopefully the rear main will go in smoothly this time and I can go raise some hell with no more high voltage opti!
Will get pics soon.
Old May 17, 2006 | 06:14 PM
Re: LTCC is installed!
Where did you end up putting the coils?
Old May 17, 2006 | 06:17 PM
cjmatt's Avatar
can u run an msd unlike the delteq?
Old May 17, 2006 | 06:26 PM
Loadre's Avatar
Got impatient and couldn't get a plasma cutter or band saw quick enough to mount them under the radiator like I wanted so they are up on the valve covers unfortunately. This also allowed me to not have to order custom Magnecor wires as I could reuse my Accell Extreme 9000's for a while. I'll get some pics tonight or tomorrow. 16 gauge steel is a biotch to work with when you don't have the right tools.
The only external thing I need to run is a window switch. The LTCC box has everything else I need built in.
Old May 20, 2006 | 12:28 PM
Loadre's Avatar
Old May 20, 2006 | 12:33 PM
Loadre's Avatar
Pics suck but you get the idea.
Old May 21, 2006 | 05:15 AM
MeanGreen97Z's Avatar
Stick with mechanic work because you are a horrible photographer.
J/K! It looks good man! I'm beginning to think I should do this to my car. Think it might get you a little better gas mileage?
Old May 21, 2006 | 06:43 AM
joeSS97's Avatar
Looks like a nice install job.I like it.Needs a little paint.Or are the mounts stainless?
Old May 21, 2006 | 09:48 AM
FastZinTennessee's Avatar
Looks good man! No more opti, for the win.
Old May 21, 2006 | 10:29 AM
Loadre's Avatar
Depending on the current state of disrepair that your opti is in, switching to LTCC could possibly increase mileage.
Mounts are just mild steel, I'll probably spray them black next time I take them off.
Old May 21, 2006 | 10:04 PM
1BadZ95's Avatar
I got the LTCC when I got my car and would never own a LT1 with out it!
Old May 21, 2006 | 10:07 PM
sleeperMULLET's Avatar
i have a dumb question, what is a LTCC?
Old May 22, 2006 | 12:21 AM
Loadre's Avatar
It's a box that converts the low voltage (optical) part of the opti into a signal that fires 8 individual coils instead of the high voltage part of the opti.
Old May 22, 2006 | 01:22 AM
MikeSS97's Avatar
where can the stuff needed to convert to this set-up be bought and how much does it run????
Old May 22, 2006 | 02:46 AM
sko_spo's Avatar
ok question here - Isnt possible for ppl who have ram air, to install the coil packs in the former air intake spot? Or just relocate the battery to the rear and place the coils over there? I just think it would be better then the rad mount position or trying to place them on the crowded valve covers . IMO
