LTCC is installed!
LTCC is installed!
Took the car out last night after replacing the rear main seal and putting in the LTCC. The car has never run that good in the past 3 years. Didn't get on it yet because the rear main was still leaking like hell and already getting ready to pull the tranny again, just thought I would share this while I'm taking a break from the car.
Can't wait until tomorrow hopefully the rear main will go in smoothly this time and I can go raise some hell with no more high voltage opti!
Will get pics soon.
Will get pics soon.
Re: LTCC is installed!
Originally Posted by Injuneer
Where did you end up putting the coils?
can u run an msd unlike the delteq?
Originally Posted by Loadre
Pics suck but you get the idea.
J/K! It looks good man! I'm beginning to think I should do this to my car. Think it might get you a little better gas mileage?
Depending on the current state of disrepair that your opti is in, switching to LTCC could possibly increase mileage.
Mounts are just mild steel, I'll probably spray them black next time I take them off.
It's a box that converts the low voltage (optical) part of the opti into a signal that fires 8 individual coils instead of the high voltage part of the opti.
ok question here - Isnt possible for ppl who have ram air, to install the coil packs in the former air intake spot? Or just relocate the battery to the rear and place the coils over there? I just think it would be better then the rad mount position or trying to place them on the crowded valve covers . IMO
