ltcc install
Old Oct 18, 2004 | 02:36 AM
acslinger2525's Avatar
ltcc install
I have the LTCC kit, my question is, my opti has went out again, i cant tell you what caused it, it just went out. Do i need to replace the opti before i put the ltcc kit on? Does anyone have a really good outline/instructions how to put this kit on a 1997 Z28?
thanks people
SC Smith
Old Oct 18, 2004 | 11:25 AM
94 NO TOP Z's Avatar
Re: ltcc install
The low voltage part of the opti must be working for the LTCC. YOu probably need to change it.
Old Oct 18, 2004 | 12:01 PM
ejfagala's Avatar
Re: ltcc install
The most common failure in a Opti is the high voltage side. Just install the LTCC and see if it works, you realy have nothing to loose. If it works great your up and running in 1/2 hr , if it doesn't you didn't loose anything and will need to replace the opti. This will also take care of a coil if it went bad.
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
