LT4km Worth it
Old Dec 27, 2003 | 01:59 PM
All4Chevy's Avatar
LT4km Worth it
I just started reading about the LT4KM and it seems that its worth getting once i get my longtubes in...but is there any reason that i should not get it now? The headers wont be in for a couple of months....but can the knock module hurt anything? I figure i might as well do it because theres no reason not to.
Bill
Old Dec 27, 2003 | 02:07 PM
Antz97ZNJ's Avatar
I had one on my 97, notice a little smoother uptop, some have noticed alot more. For 30 bucks why not and it takes 2 seconds to install
Old Dec 27, 2003 | 02:21 PM
Hyperspeed97z28's Avatar
I agree with the above post, its something you will need sooner or later if you plan to upgrade alot...
Old Dec 27, 2003 | 02:24 PM
AxeGrinder30thZ's Avatar
I got one for Christmas and put it on just a couple of hours ago. I have SLP headers and true dual Bullets. Seems a little more smooth and not as rough. I think it helped out well.
Old Dec 27, 2003 | 03:03 PM
ibanez6rg's Avatar
Worth it IMO - Helps get rid of that false knock, in which could hurt performance.
Old Dec 27, 2003 | 03:25 PM
OBE1 95Z28's Avatar
There are 2 kinds of knock, true knock and false knock. Noiser valve trains (1.6 RR's) and headers produce more mechanical noise. This noise can be picked up by the knock sensor and interpreted as predetonation. The LT4 engine came with RR's and the LT4 knock module was tuned to not listen to this mechanical noise, therefore less prone to false knock. Chances are your long tubes will increase your mechanical noise.
Old Dec 27, 2003 | 03:39 PM
Heatmaker's Avatar
Advanced Member
Get it it's a very necessary item. It's up there with the 8mm wires and plugs. If you plan on making more power your going to need it.
Old Dec 27, 2003 | 03:40 PM
RallyRed701/2's Avatar
i have long tubes going through stock exhaust. i didnt think i was picking up that much false knock if any, but when i put in the lt4km and with cold weather i actually picked up about .4 in the quarter.... i was like
its worth it... especailly since its so cheap...
Old Dec 27, 2003 | 04:12 PM
drewstealth's Avatar
Yeah just get the LT4 KM. It won't hurt anything if you install it. It can only make things better. It only takes like 5-10 min to install it also. You can have false knock on a stock car. I only have hooker catback and slp cai and i was seeing 4-5* of false knock. I have no more false knock now with the lt4 km.
Old Dec 27, 2003 | 04:37 PM
SiDeWaYZz28's Avatar
is the lt4 km bad for supercharged engines?
Old Dec 27, 2003 | 04:49 PM
no
Old Dec 27, 2003 | 05:32 PM
96b4ccamaro's Avatar
what if you run shorty headers out of a cut out with no cats will that give a false knock?
Old Dec 27, 2003 | 06:06 PM
ibanez6rg's Avatar
Anything can give you false knock really.
Devinfoote87
Feb 12, 2016 03:21 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
