LT4 Valve Cover Gaskets Part #'s Needed
Old Jul 12, 2004 | 12:10 PM
944v8inDFW's Avatar
Talking LT4 Valve Cover Gaskets Part #'s Needed
Got my whammy jammy LT4 valve covers today. Does anyone have the GM or Felpro part numbers for the gaskets handy? Yes I checked ShoeBoxes site and did a search first. Thanks
Old Jul 12, 2004 | 12:31 PM
No, I don't have that on my page, but I think I found it for you.
GM PART # 10108625
Didn't yours have any gaskets?
Old Jul 12, 2004 | 12:35 PM
Mtrhds94Z's Avatar
GM part #'s for LT4 covers:
10108625- LT4 valve cover gasket [2 req'd]
10108674 - Stud,Valve cover mounting [4 per Valve cover]
10108675- Bolt,Valve cover mounting [ 4 per valve cover]
12555685- Cap, Oil fill [ 1 Required for psgr valve cover only.]
10240678- Grommet, pcv [1 Required. Comes with the psgr valve cover. ]
10108626- Seal, mounting bolt [8 req'd,1 per bolt ]
'Valve cover Gasket Mounting Bolt Seals' are included with the covers. Psgr cover comes with PCV grommet. The rest of above mentioned parts are not included, and must be purchased seperately.
Old Jul 12, 2004 | 12:39 PM
944v8inDFW's Avatar
Weird factory sealed in plastic. 1 Had seal 1 did not.
Old Jul 12, 2004 | 12:52 PM
Mtrhds94Z's Avatar
Added a few more #'s
Old Jul 12, 2004 | 12:53 PM
Both of mine came with the gaskets. Did you get the 12555685 oil cap, too?
Charlie, you listed the gasket p/n for the bolt seals too.
Old Jul 12, 2004 | 12:54 PM
944v8inDFW's Avatar
shoebox got everything except 1 gasket. got correct cap and studs.
Old Jul 12, 2004 | 01:00 PM
Another number to throw out is 12557604, which is the Corvette PCV/CCV hose that goes from the throttle body to the RH valve cover. It does not seem to fit perfectly on my car, though. <shrug> I have a hard time trying to keep the plastic elbow from popping up from the valve cover grommet.
Old Jul 12, 2004 | 05:08 PM
Mtrhds94Z's Avatar
All fixed..
It's 10108626 not 8625
Also, I am under the impression that they come with the seals [and the PCV grommet] but not the gaskets?
Thanks Rob!..
Old Jul 12, 2004 | 05:12 PM
Mtrhds94Z's Avatar
Which seal came with ? the 4 bolt seals?
I am under the impression they come with those seals, but not the gaskets?Did you get a gasket in one?
Did the PCV grommet come with the psgr side cover?[it should]
Thanks..
Old Jul 13, 2004 | 01:59 PM
944v8inDFW's Avatar
Clear some things up and #'s
My set came 100% complete (new) with all the studs, seals, oil cap, vent grommet. What it did not come with is 1 valve cover gasket. I didn't feel like waiting for a few days on UPS ground so i bought some at my local parts store. Bougt the Felpro set because my friggin local GM dealer has to order everything (except a high service bill) Anyway the Felpro number is VS50443R. Set includes 2 VC gaskets and the 8 stud seals. Under $20 out the door with tax.
Thanks for the help.
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Snoman73
Nov 17, 2014 07:22 PM
