lt4 timing kit
Old Feb 22, 2010 | 09:47 AM
pj97ragtop's Avatar
lt4 timing kit
looking at a lt4 timing chain and gears off a lt4 crate motor it has every thing but the water pump gear are the lt1 tha same as a lt4 it has the chain, crankshaft sprocket, camshaft sprocket but no water pump gear thank you for reading this do I still need a lt4 water pump gear or will my lt1 work thanks
Old Feb 22, 2010 | 10:44 AM
RUDEDOG's Avatar
I used the stock LT1 water pump gear. No problems yet after about 30k.
Old Feb 22, 2010 | 11:45 AM
RamAir95TA's Avatar
Yeah, the stock LT1 water pump drive gear will work fine.
Old Feb 26, 2010 | 10:27 AM
Slick-Z's Avatar
Yeah the only difference is the fact that the lt-4 timing chain sprockets are made of steel for stronger applications as to where the cheaper ones are usually made of iron. The iron ones are usually good up to around 400 horses after that its usually time to upgrade. Also there are some timing degree change possibilities on the lt-4 kits which i really dont understand ive changed mine out with factory gm kit and never had to adjust because everything goes on one way
Old Feb 26, 2010 | 10:47 AM
Actually, the stock LT1 timing set is "powdered metal". From the LT4 vs LT1 comparison:
ROLLER TIMING CHAIN
Stock LT1 has powdered metal butt link chain drive for the camshaft and water Pump. LT4 has smaller but stronger steel roller chain. Although it seems that the new chain and sprockets would reduce mass, The cam sprocket was left solid, rather than webbed, specifically for additional mass. Increased inertia in the system reduces the tendency for cam torsion.
http://www.grandsportregistry.com/im...ming_chain.jpg
(copy and past link - it won't connect otherwise)
The LT4 timing set should not be confused with the LT4 Extreme Duty timing set, which is yet another design.
LeftoverChinese
Jan 14, 2024 03:03 PM
Jan 23, 2015 01:13 PM
WildRidez
Jan 16, 2015 03:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
