LT4 TB on a LT1?
Old Sep 12, 2005 | 02:00 PM
Reds929's Avatar
LT4 TB on a LT1?
Will a mid '90s (think its from a '95 or a '96) LT4 throttle body work on a '93 LT1? I need to know quick!
Old Sep 12, 2005 | 02:16 PM
anaik's Avatar
Re: LT4 TB on a LT1?
The linkage will be different. Your '93's 4L60 uses a cable for downshifts and WOT upshifts. The 4L60E, '94 up, not sure with the vette, uses an electronic signal from the PCM.
Old Sep 12, 2005 | 02:32 PM
Reds929's Avatar
So I can mod this and make it work? Its a BBK TB and i can get it pretty cheap.
Old Sep 12, 2005 | 02:36 PM
anaik's Avatar
Can't say for sure, but I've read on this board that it can be done.
Old Sep 12, 2005 | 03:01 PM
anaik's Avatar
If you can put the BBK along side your TB to see what is involved. I was thinking along the lines of putting the '93 linkage on the '94 up stock TB.
Old Sep 12, 2005 | 04:05 PM
Reds929's Avatar
Cool, I am thinking the linkages can be modded to work with the '93. If all else fails I can just sell it on ebay or here. Thanks man.
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
