LT4 Starter question
Old Mar 13, 2009 | 06:09 PM
dbrockma's Avatar
(Yes, I have read about 40 or more threads, but none addressed this)
I am going to put a new starter on my 383 built LT1. I looked at Kragen for the LT4 gear reduction starter, and my question is this:
The LT4 version does not have a 'hat' with a bearing support on the flywheel end. Is this required, or is the LT4 gear reduction have enough bearing support inside the starter?
The first link is for the LT1 replacement
http://shop.oreillyauto.com/ProductD...pe=123&PTSet=A
This one is the LT4 replacement:
They both have the same long/short bolt pattern. Just want to make sure I got the right gear reduction starter.
Old Mar 13, 2009 | 06:42 PM
Most high torque starters look like the LT4. It should not be an issue. Lots of people use them.
Old Mar 13, 2009 | 10:04 PM
94Camaro_Z_28's Avatar
I've got it on mine, works fine.
Old Mar 14, 2009 | 02:28 AM
madhatter's Avatar
Mine is 5 years old and has over 35k miles on it. You wont have a problem.
Old Mar 14, 2009 | 09:31 AM
CreatiVe2's Avatar
i have a 3hp powerstart i got from a seller on ebay. comes with all hardware, and works beautifully!!
http://www.facebook.com/photo.php?pi...e5&id=35904193
http://www.facebook.com/photo.php?pi...57&id=35904193
2 long screws to install.
Old Mar 14, 2009 | 12:27 PM
dbrockma's Avatar
Now THATS a starter. If you had enough juice.... you could probably drive home on that beast!
pimpss96
Feb 12, 2015 01:28 PM
ModdedNerd
Jan 29, 2015 07:23 PM
WildRidez
Jan 16, 2015 03:10 PM
95chwagon
Jan 13, 2015 09:19 PM
Jeff1904
Jan 3, 2015 12:00 AM
