LT4 Starter Install
Old Mar 14, 2009 | 12:58 PM
Laymaster's Avatar
LT4 Starter Install
I have an LT4 starter and tried to install it some time back ago. I got my old starter out just fine but could not get the LT4 starter in. I noticed it was just a bit bigger than the LT1 starter (or so I remember that) but I could not finagle it through the exhaust. I have MAC shorties and a BORLA exhaust, which wasn't there the last time I had to change a starter.
Would dropping the exhaust be mandatory at this point? Or am I just bad at angling the stuff? I've done plenty of work under the car before and found ways to get things through weird angles.
Anyone else drop the exhaust?
Old Mar 14, 2009 | 05:19 PM
Laymaster's Avatar
I had the car up high enough to get me under it, and I've done plenty of work under it. I thought it definitely had to do with the shorties and y-pipe.
Old Mar 14, 2009 | 05:31 PM
zcardriver22's Avatar
I had to drop mine just to get the old starter out. Didn't seem to matter which angle I tried removing it that thing just wasn't coming out, not a big deal only took a couple of minutes. My setup was completely stock at the time.
Old Mar 14, 2009 | 07:42 PM
Jazsun's Avatar
I didnt have to drop mine to get the orignal lt1 starter out but i did have to drop it to get the lt4 in.
Old Mar 15, 2009 | 01:23 PM
flyinZ's Avatar
I wonder if this starter will work, if your running a stepped LT?
Old Mar 15, 2009 | 05:08 PM
Laymaster's Avatar
what's a stepped lt?
just running MAC shorties with Y pipe, cat, and borla.
Old Mar 15, 2009 | 06:11 PM
a stepped header gets bigger as you move further down the pipe. example would be 1 3/4 to 1 7/8
Old Mar 15, 2009 | 07:15 PM
flyinZ's Avatar
Yep, thats it. Thats what Im running now, and i can see a starter upgrade in the near future..And wasn't for sure if the LT4 starter would fit.
Old Mar 15, 2009 | 07:40 PM
slowZ's Avatar
i've got mac mids and if i remember correct i had to drop the y-pipe to get it in, and also i had to put a dent in the header because the one bolt that holds the starter together was right against it. hope you dont have to go those lengths
Old Mar 15, 2009 | 08:23 PM
RamAir95TA's Avatar
I had to drop my MACs as well.
Old Mar 15, 2009 | 08:30 PM
Laymaster's Avatar
Joe, that you? How have you been?
And..thanks for the info.
Old Mar 17, 2009 | 02:23 PM
hsyr's Avatar
LT4 wouldn't fit with my Jet-hot LT's. Would have required to seriously dent my headers.
Old Mar 17, 2009 | 02:50 PM
madhatter's Avatar
That is weird. My 94 had Jet Hots and a LT4 starter. No issue whatsoever.
Old Mar 17, 2009 | 05:46 PM
kyle88transam's Avatar
I had to drop the y-pipe on a friends car with mac mids.
Old Mar 17, 2009 | 07:14 PM
RamAir95TA's Avatar
Yep - it's me. Hahah...the one and only.
