LT4 Starter Install
LT4 Starter Install
I have an LT4 starter and tried to install it some time back ago. I got my old starter out just fine but could not get the LT4 starter in. I noticed it was just a bit bigger than the LT1 starter (or so I remember that) but I could not finagle it through the exhaust. I have MAC shorties and a BORLA exhaust, which wasn't there the last time I had to change a starter.
Would dropping the exhaust be mandatory at this point? Or am I just bad at angling the stuff? I've done plenty of work under the car before and found ways to get things through weird angles.
Anyone else drop the exhaust?
I had to drop mine just to get the old starter out. Didn't seem to matter which angle I tried removing it that thing just wasn't coming out, not a big deal only took a couple of minutes. My setup was completely stock at the time.
i've got mac mids and if i remember correct i had to drop the y-pipe to get it in, and also i had to put a dent in the header because the one bolt that holds the starter together was right against it. hope you dont have to go those lengths
