Lt4 springs good for this cam?
Old Jan 6, 2005 | 03:29 AM
redcamaroz28's Avatar
The cam is 209/217 .496 .517 w/ 1.6 rockers. From the searches that I've done, people say the Lt4 springs are good from anywhere to .515-.530 I assume they will be fine since the hotcam kit comes w/ these and it is a bigger cam w/ I believe .525 .525 lift but I guess I'm just looking for some reassurance since I've already given my heads and lt4 springs to the machine shop
Ryan
Old Jan 6, 2005 | 08:26 AM
stereomandan's Avatar
Re: Lt4 springs good for this cam?
They should work great unless the lobes on the cam are really aggresive. It's not like an EX grind is it?
I'm putting in LT4 springs on my stock cam, and am thinking of leaving them in when I put a cam in, which has 214 degrees on the intake with 0.521" lift. I'll need different springs for the exhaust though since it's lift is more like 0.543"
Dan
Old Jan 6, 2005 | 10:29 AM
LT4383's Avatar
I ran the LT4 springs w/ a CC305 and 1.6's. Probably not the safest thing, but it worked for more than a year w/ several 6400 pulles.
Old Jan 6, 2005 | 10:34 AM
aintno6's Avatar
why risk it, seriously?
Can you imagne how pissed off you would be if your float a valve, and it puts a hole or crack in your piston(s)?
Just my .02,
Mike
Old Jan 6, 2005 | 10:38 AM
LT4383's Avatar
Just my .02,
Mike
Agreed, I was young and coouldn't afford. Just stating what I did, not telling him what to do.
Old Jan 6, 2005 | 10:46 AM
aintno6's Avatar
Oh sorry man, I didn't mean to point that towards you. It was towards him.
Old Jan 6, 2005 | 12:14 PM
cat1055man's Avatar
Ryan,
The LT-4 springs supplied with the hot cam kit should work very well with the cam you are installing. I have installed them with the hot cam and there is no sign of valve float at 6200rpm, .525" lift. 1.6 rockers.
MadMav
Feb 6, 2015 11:02 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
95chwagon
Jan 13, 2015 09:19 PM
