LT4 springs
Old Jan 24, 2009 | 03:49 PM
  #16
lt1-xjs's Avatar
Originally Posted by n2ceptor
I run lt4 springs with a Crane 227, and 1.52 CC rockers in my 93Z with no problems..
No sig.? Times and numbers would be nice.
Old Jan 24, 2009 | 04:43 PM
  #17
Kevin Blown 95 TA's Avatar
Originally Posted by deerslayinrenek
Can anyone explain to me what the shims are for?
and also is there a legit reason why i would want the lighter LT4 retainers compared to my stock LT1 retainers?
You dont need the LT4 retainers, but they are a tiny bit lighter. I know because I weighed them both at one time and if I remember correctly, there was a couple grams difference, something that will never matter on a stock cam.
Some guys set all the springs at the same height, which uses the shims because the valves do not all stick up the same amount, especially on reworked heads. This a good baseline but it doesn't guarantee that all the springs will have the same pressure. To acheive that, you have to test each spring individually on a load cell and see what height they make the desired spring pressure, then shim them to that height assuming your clearances are all OK.
But, if I were you, I'd just stick them in at the correct height and you'll be fine. The 1.6rrs + LT4 springs is a GOOD upgrade over stock, especially on an older car with worn out springs.
Old Jan 24, 2009 | 05:27 PM
  #18
deerslayinrenek's Avatar
Thank you I appriciate the info from you and everyone else. This was just a little project to get me started on this car, i was putting new lifters in it and I figured why not put some money in it while I was doing it. It has an AC Delco Reman Short block in it that is suppose to have about 25,000 miles on it. It seems like a pretty strong engine but in the future I wanna drop the engine and rebuild it and add some LE heads and Cam but that's a little farther down the road. It's my daily driver so that's a problem as I'm forced to run my 8mpg dually truck everyday, which happens to be a ford
Old Jan 24, 2009 | 05:44 PM
  #19
n2ceptor's Avatar
Sig?? I have a quote..... Just my DD... Its never been to a track.. But I estimate low/mid 13s'.. It has gone 154~158 MPH by police hand-held radar...
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
