lt4 springs
Old Feb 9, 2004 | 09:45 PM
Coolformula's Avatar
lt4 springs
LT4 valve springs are they good enough for the hotcam. I'm going to get 1.66 RR's
what about these Isky 235-D Chrome Silicon Valve Springs, 1.260 OD Single Spring w/ damper, suitable to .550 lift, set of 16 (Special Expires 2/14/2004)
$89.99
Special! $80.99
CRN-10308-1
thanks i might eventuallly get a cam a bit more than then the hotcam
Old Feb 9, 2004 | 10:26 PM
truedualws6's Avatar
I have the LT4 Hot springs on now with a stock cam
and 1.6:1 rockers. The springs have worked fine for
me. I would recommend different springs with the
Hot cam and more than 1.6:1 rockers.
I will be putting in the Isky 235-D springs next, but
only because I will not go beyond 0.553" lift in the
future. I think the Isky's would be better than the
GMPP Hot springs just because you have a greater
safety margin. You are looking at 0.545" lift with the
Hot cam and 1.66:1 rockers.
If you use a 0.050" safety margin the Hot springs are
only good for 0.510" lift, why they run them to 0.525"
has always seemed strange to me.
Old Feb 9, 2004 | 11:51 PM
TMorgan800's Avatar
What springs come stock on LT-4 heads?..
"hotsprings"... that just sounds funny.
Old Feb 9, 2004 | 11:55 PM
GhostZ's Avatar
I was seeing a lot of float with my old hotcam and springs.
Old Feb 10, 2004 | 12:48 AM
Steve in Seattle's Avatar
There are no LT4 Hot Springs. The LT4 Hot Cam kit comes with LT4 springs. Some feel the LT4 springs are insufficient for the Hot Cam, but the combo seems to work ok.
Old Feb 10, 2004 | 05:44 AM
$89.99
Special! $80.99
Does this kit have everthing I need retainters etc? thanks. I would like to be on the safe side with things and get a sufficient spring.
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
